Ive put my vhs ind to composite on the wintv card, but i can find out how to capture the signal??? Which program to use? Ive got Pinnacle Studio 14 HD Ultimate but i cant find ANY capture funktion in there?? Plzz heeeeelp
Hauppauge cards come with capture software for Windows and it can almost impossible to get anything else to work with their cards. Some of their newer HD capture cards use ArcSoft ShowBiz for capturing, but I am not familiar with your card and you may need to use a different program. Sorry, but you'l have to figure out what capture software comes on the DVD that came with your card and install it.
I think WinTV 6 is the capture software Hauppauge originally supplied for this card. Do you have the installation disc?
It has a MPEG-2 hardware encoder and is supported by a number of PVR applications for recording TV, but pure capture support for this card is probably not good.
Happauge WinTV-PVR 500/1600 Streaming
By valis77 in forum Capturing and VCRReplies: 1Last Post: 1st Mar 2011, 22:47 -
capture VHS with Hauppauge PVR 150?
By shun in forum Capturing and VCRReplies: 13Last Post: 24th Jul 2010, 18:11 -
Troubleshoot capture in Linux, Hardy x64, Hauppauge PVR-500
By cwb in forum Capturing and VCRReplies: 9Last Post: 2nd May 2010, 23:54 -
Help with Hauppauge PVR 500.
By seymoria in forum Capturing and VCRReplies: 0Last Post: 24th Jul 2008, 04:27 -
Video Capture with Wintv PVR 500
By radink in forum Capturing and VCRReplies: 3Last Post: 11th Aug 2007, 14:05
