I live in Venezuela and recently I bought a Bluray LG BD550. It has been a good equipment, with an excelent audio output as well as video to an hd tv using the hdmi cable. I want to connect it to a home thater system, but it will happen in the future.
This BluRay has a wired conection to Internet, and I have downloaded the latest firmware update from LG. So far so good.
My problem is that the equipment comes with no installation of netCast, even when the specification said it is able to be connected to internet to see some contents, like Netflix or Youtube.
I call LG support service, and they tell that the NetCast option is disabled for Venezuela, Argentina and Panama. Anyone in this forum knows how to install it? and where to download the NetCast?
Thanks in advance
Darío
Results 1 to 12 of 12
Netcast is an LG service.
It needs to be part of the firmware. LG would need to enable it through your internet connection so they would know your location.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I have a BD550 (USA version) and the Netcast options where there from the start. I suspect they just don't provide those options in Venezuela. Netflix definitely won't be available in Venezuela due to licensing issues.
Starting this year, Netflix is available here in Venezuela. I don´t know why LG had disabled the netcast option in BluRays sold here. Any clue?
Ah, I hadn't heard that Netflix started streaming in Venezuela recently. The BD550 is over a year old (the BD6xx models hit the shelves in spring of 2011) so it probably won't be updated to support Netflix in Venezuela. Maybe they just decided to disable all the streaming options in Venezuela? You may need to wait and buy a new model after the spring 2012 refresh.
But I don´t want to buy a new model. I mean, I can´t buy a new one soon. This BD was bought a couple of months ago. I just want to know if someone has a LG BD550 ROM (or an update) that contains the Netcast options.
Or if someone knows where can I download it to install the software in my bluray
Thanks again
darío -
Can you download from here (USA site)? http://www.lg.com/us/support-product/lg-BD550#
Sorry, but I haven't tried yet. Actually, I downloaded the file, and it was bigger than the update that I downloaded previously from LG Panama site. I think that I'll try it next weekend. I'll let you know how it was. Thanks
Chilenomaldito has not logged in here since April of last year. Probably since making post #10 above. You will probably have to send him a private message and hope he reads it.
Problems playing .mkv on a LG BD550
By Pipster2797 in forum Blu-ray RippingReplies: 15Last Post: 9th Jan 2017, 06:53 -
Being able to set region code in LG BD550 blu ray player
By bevivek in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2011, 06:11 -
lg bd550
By sassi in forum Latest Video NewsReplies: 1Last Post: 1st May 2011, 04:46 -
LG BD550 - MKV playback Issues
By Khalua in forum DVD & Blu-ray PlayersReplies: 5Last Post: 18th Apr 2011, 09:52 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43
