Results 31 to 35 of 35
http://www.kiva.org/about -
In VirtualDub: open the file, add the bob double filter, step through the video frame by frame with the right arrow key. If you get two-steps-forward-one-step back motions you have the wrong order selected in the bob double filter.
In AviSynth you can use AssumeTFF().Bob(). Step the video frame by frame as with VirtualDub. If motions are ok your video is tff. Else bff. You can also use AssumeTFF().SeparateFields().
DVD is usually TFF. DV is BFF. Different capture devices will capture with different field orders. If you pick the wrong field order you will get very fast jerky motions on playback. -
Thank you jagabo. A little over technical for me, but I'll do some more testing and learn
Regards. -
Wonderful post, and I've learned a lot.
Hey, jagabo, Sosigene, i admire your spirit of study.
Question about DECOMB and IVTC in BDRB
By mrswla in forum Blu-ray RippingReplies: 4Last Post: 17th Feb 2011, 17:20 -
Decomb IVTC issue
By iamtehsux in forum DVD RippingReplies: 9Last Post: 1st Mar 2009, 03:48 -
Deinterlace or Decomb or Interlaced?
By cr9ck in forum Authoring (DVD)Replies: 9Last Post: 5th Dec 2008, 12:14 -
AVI.NET---- What is and do I need to decomb/deinterlace?
By siratfus in forum Video ConversionReplies: 4Last Post: 4th Aug 2008, 00:09 -
Anything like D.Graft's Decomb available for RGB ?
By grannyGeek in forum RestorationReplies: 5Last Post: 18th Jul 2007, 23:20
