Hi all,
I am trying to add permanent subtitles to a MKV file using mkvmerge.
I am selecting a MKV file and adding an SRT file.
The movies plays fine on my computer but on my TV the movie does not play at all and I get a message that the file type is not supported. before I add a subtitle file and/or encode the movie with mkvmerge, the TV plays the movie fine.
Any help????
Thanks.
You can't do it with mkvmerge.
You must use a converter/editor like avidemux, xvid4psp or freemake video converter to burn in/hardcode/permanent subtitles.
See https://forum.videohelp.com/threads/331848-How-to-easily-convert-everything-to-anything...d-in-subtitles and https://forum.videohelp.com/topic360276.html -
Or it could just be that you have forgot to disable header compression in mkvmergegui, under file->options and select disable header compression removal. Then restart mkvmergegui and add your mkv and srt. But it wont create permanent subtitles in the mkv...but it might work anyway.
I used freemake video converter to do the same with a MKV file and it works very nicely except for one issue if you have 2 lines of subtitles the bottom line overlaps the frame line and on 3 modern LED TV half the bottom line is obscured. The program doesn't have any facility to raise the subs further up into the picture area. If you were watching on a CTR TV I suspect both lines would be obscured. Pity as it is a quick and simple program to work with. I have emailed the company and did get a reply that they will look into it sometime....
I not sure if this will work but I am going to experiment converting the srt format into ass that gioves a bit more flexibility and maybe I can create a set that will be higher in the video ? Any thoughts anyone on that appreciated....SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Any converter that allows you to use AviSynth scripts, you can use VSFilter to "burn in" the subtitles. See docs on TextSub() for adjusting the style of the subs. Alternatively, you can use AviAddXSubs to create idx/sub subtitles with control of font, border thickness, placement etc... then add them using the VobSub() function.
To see how it will look before encoding you can use AvsPMod or another AviSynth tool that has a preview function.
edit: whoops! Forgot the vsfilter docs page:
http://avisynth.org.ru/docs/english/externalfilters/vsfilter.htmhttp://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
How do I add permanent subtitles 720p MKV video
By Torresinho in forum SubtitleReplies: 1Last Post: 15th Sep 2011, 20:16 -
Adding subtitles to MKV file
By drgt in forum Newbie / General discussionsReplies: 8Last Post: 29th Dec 2010, 10:04 -
Suggestion: Adding stickies for HQ output and permanent subtitles
By Ceesar in forum SubtitleReplies: 0Last Post: 23rd Oct 2010, 18:00 -
Adding .ass subtitles to a MKV file using mkvmerge
By tyson123g in forum SubtitleReplies: 14Last Post: 13th May 2010, 00:03 -
Adding permanent subtitles to MPEG2
By MrJacky in forum SubtitleReplies: 17Last Post: 10th Oct 2009, 13:30
