We are creating an iOS application that uses the High Definition video recorded on the iPhone. We need to convert the video into a medium quality video to drastically reduce the file size before uploading, is there a way to do this? When upoading to YouTube it seems to compress/convert the video first on the iPhone, so there must be a way, we just can't find it after days of looking feverishly. Is there any codec like ffmpeg for iOS? I know we can convert video using ffmpeg in php, but how to do that in iOS5?
Thanks for any advice guys!
Shawn
Results 1 to 9 of 9
sorry but running an encoder on an ios device would be rather dopey. their processors are not up to it. offload it to a pc or mac.
Thanks aedipuss, but YT somehow does it with videos uploaded from the iPhone to YT. And we can offload it to a server for encoding, but that still means the user has to upload a behemoth file only to have it chopped down for web playback...seems cumbersome, ya know? Plus it will eat up the user's monthly data transfer.
Any other suggestions? -
afaik (never tried) it theory it should be possible to:
1. build ffmpeg with x264 support for iOS (see: https://github.com/rodisbored/ffmpeg_x264_iOS5_build)
2. use ffmpeg you recompress a video
"but YT somehow does it with videos uploaded from the iPhone to YT"
are you sure about this, afaik that is not the case,...
That's how YT works,.. you upload a video, they reencode it to different resolution and bitrates (using an old x264 version with ffmpeg)the user has to upload a behemoth file only to have it chopped down for web playback...seems cumbersome, ya know
Cu Selur -
Thanks Cu Selur. Do you have an iPhone? If you do you can see that some process is run first, before the upload begins, to compress the video. Our tests show that the uploaded file is much smaller before upload, which is what we're trying to accomplish without YT.
I do appreciate the feedback! -
iMovie is the app that compresses the vids before uploading. the only way i located to upload in a different format is to offload from the phone first then upload.
there are a bunch of ios video editing apps - maybe contact one of the authors to see what they use to encode with.--
Ffmpeg N/A video conversion problem
By livestream in forum Video ConversionReplies: 3Last Post: 15th Sep 2011, 16:17 -
Encoding for iOS platforms?
By adrianle in forum Video Streaming DownloadingReplies: 2Last Post: 10th Sep 2011, 19:18 -
php-ffmpeg video conversion
By Tonybot in forum Video ConversionReplies: 6Last Post: 7th Jun 2011, 03:37 -
By Tonybot in forum ProgrammingReplies: 1Last Post: 6th Jun 2011, 02:36 -
IOS Conversion tool - similar to mkv2vob?
By marsyas91 in forum Video ConversionReplies: 2Last Post: 29th May 2011, 13:47
