I have Blu-Ray 3D .iso's and I want to add subtitles to them. Is this possible?
The only thing you should really know is that I want to add subtitles but I NEED to have the 3D .iso as end result to burn them on a BD-R DL disc!!!
Can this work in some way?
Not any easy method. You must extract and reauthor...and you will lose menus, extra material.
thxz for your reply Baldrick. Don t care about extra's and menu's. Can you help me on my way what I will need for this to do? What s most important to me:
1. No quality difference compared to the 'original' .iso
2. Final output file HAS to be an burnable (BD-R DL) .iso -
As Baldrick said, you must extract & re-author. Do you have a BD3D authoring app? (e.g. Vegas 11 Pro, Scenarist 5.2+, PowerDirector 10, etc)
Without it, you're SOL.
You'll also need a subtitle tool that knows how to create "3D subtitles" with the dynamic stereo3d window offsets required (otherwise, you'll end up with titles that "ought to be in front" but appear to your brain BEHIND objects in the show).
Scott -
is there a new easier way to do it now? im also looking for a way to add a 3d sub to a 3D iso i have that only has german subs
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 16:53 -
adding subtitles
By dabud in forum Authoring (DVD)Replies: 3Last Post: 20th Oct 2009, 23:27 -
Adding subtitles
By tommcd64 in forum Authoring (DVD)Replies: 7Last Post: 28th Aug 2009, 01:39 -
Adding subtitles
By Avril in forum MacReplies: 14Last Post: 18th Jan 2009, 14:43
