I have tried using Powerdirector 10 ultra but was so dissapointed that you are not able to add more effect tracks, you can add video and audio but not effects or other tracks. So no flexibility.
I need this cause if I want to add the same effect to 4+ objects in the scene and the software just cannot do that.So let saying adding motion blur for speed for 6 people and making it looking like all of them are just speeding away fast at the same time.
So Like to know can the Platinum Production Suite 11 be able to handle this sort of requirement and flexibility? I know you can make several video tracks and add the effect to that but that will take up space. If you need to edit a movie and clear things up on it the size would increase I think if they are duplicate scenes ontop of each other. So its not something I like....
Also are they any other good proffessional software that can do this too? Like to know...
Thanks!
Results 1 to 1 of 1
Premiere Elements 9 or Sony Vegas Movie Studio HD Platinum 10 Suite?
By HoosierGuy in forum EditingReplies: 37Last Post: 26th Feb 2011, 00:55 -
VideoRedo TV suite 4
By nirbhayn in forum EditingReplies: 0Last Post: 19th Jan 2011, 15:56 -
Worth upgrading from sony platinum 8 to platinum suite 10?
By helper in forum EditingReplies: 0Last Post: 30th Jul 2010, 00:30 -
Anyone using Magic Bullet Looks Suite 1.1 to 2.1?
By cooldude859 in forum EditingReplies: 0Last Post: 7th Jan 2010, 03:31 -
Best All-In-One Security Suite
By Nitro89 in forum ComputerReplies: 10Last Post: 29th May 2008, 19:35
