Hi,
I had a .mkv file and eng .srt file. I used tsMuxeR GUI 1.10.6 and add both the .mkv and .srt files. The resulting .m2ts file didn't show the subtitles on my PS3. I can hear audio and video on PS3 but no subtitles. I checked the options and PS3 says there are no subtitles.
I am new at this. Am I doing somthing wrong? Do I need to use some other tool?
Thanks in advance,
Joe Green
Use multiavchd and ouput to ps3 if you are putting it on a usb drive,
Usually I copy them to PS3 hard drive over the network and play. USB stick is fat32 and won't be able to handle file size larger than 4 GB. My video is larger than 4GB so will AVCHD option still work?
Just do what i mentioned,multiavchd will split the file so you can put it on a usb drive.
Subtitles with m2ts file ?
By sn0wer in forum SubtitleReplies: 6Last Post: 3rd Apr 2010, 17:55 -
How to put subtitles in a m2ts file ?
By sn0wer in forum MacReplies: 4Last Post: 18th Mar 2010, 11:52 -
(Newbie) How to add srt file to m2ts files
By Bronco99 in forum SubtitleReplies: 1Last Post: 23rd Jan 2010, 14:04 -
Subtitles keep disappearing from M2TS file
By Omicron91 in forum Media Center PC / MediaCentersReplies: 3Last Post: 18th May 2009, 04:05 -
How to add subtitles to an HD .ts file?
By naboth in forum SubtitleReplies: 4Last Post: 22nd Jun 2007, 21:39
