I am looking to increase the volume on a DVD and its been a long time since I have done anything with DVDs etc etc. If I recall I need to DE-MULTIPLEX the file, alter the audio to what i require and the MULTIPLEX it back together again, Am i on the right lines.........I have TMPGenc Studio installed on my PC. The dvd file has been ripped using SHRINK and is in the VIDEO_TS and AUDIO_TS folder mode. Do I need to convert the DVD file into another format so I can achieve my goal ?
Demux with pgdemux.
Fix audio in audacity or something.
Reuthor with muxman.
Add back menu with vobblanker. -
Rarely is it the case of DVD Audio (usually Ac-3) being TOO LOW. It's usually the case that everything else is TOO LOUD.
Seriously, AC-3 has "dialnorm" which attempts to set the level so that on consumer devices, most programs will have an AVERAGE sound that is consistent.
Many consumers/prosumers/hobbyists will overuse "Normalize" to maximize the peak level regardless of any varying peak-to-average ratio changes from program to program. (and those other formats add to the problem with no support for dialnorm)
Think about it this way: I have a recording of a pin dropping and a cannon firing. If I Normalize BOTH, the sound of the pin dropping will be similarly as loud as the cannon - which should NOT be the case.
When you do need to do a consistent RMS/Average levelling, ReplayGain is a good way to go...
Scott -
Thanks for the replies. I have managed to DE-MUX the DVD file which creates an AUDIO WAV file and a VIDEO M2v file. I can also MUX them back together succesfully. HOWEVER if I alter the audio track MUXMAN will not accept the altered audio file. I use a program called Multiquience to alter the WAV file. Any suggestions ?
Ripbot Flac for Audio - volume too low
By AndyD in forum Blu-ray RippingReplies: 2Last Post: 10th Sep 2010, 19:55 -
Low audio volume
By Daz_uk in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2010, 13:34 -
DVD footage with low volume CAN WE FIX IT ??
By rockonvidtrade in forum AudioReplies: 7Last Post: 11th Jan 2010, 11:27 -
FairUse Wizard Audio Volume too low
By herzeleid in forum DVD RippingReplies: 1Last Post: 11th Oct 2008, 19:05 -
My TV Caps have Low Audio Volume and Hiss - ATI AIW 2006 PCIE
By somebodeez in forum Capturing and VCRReplies: 16Last Post: 26th Apr 2008, 07:08
