Hello,
I need to find a easy way to project subtitles under a big projection screen. I will use 2 projectors - one for the video and one for the subtitles.
The complicated thing is to sync the two. Is there a way to do this?
If not I would be ok with a program that will show just the subtiles on the projection and has controls when to switch to the next line of subtitles. I could prepare the subtitles in a txt file and manually sync them durring the projection. Is there a software that does this?
Thank you.
Subtitles workshop is for syncing subtitles in the film and playing them together, but here I will have two laptops, one will play the film, that will probably have a burned in subtitle and the other laptop will play another subtitle (in a different language). The laptop that plays the subtitles should be able to project the two lines of dialog on a black screen at the top of the screen. If you position the subtitles projection under the film projection, it will look like another set of subtitles under the film. This is what i want.
Just found this program, it may work for you.
http://justsubsplayer.codeplex.com/releases/view/51264 -
I would think there would be a software player that could handle this with only one PC.
You want to play a movie and put subtitles immediately below the frame or in a separate window.. I know I could do this with my old ATI player. Fullscreen and then project the whole desktop. Subtitles automatically synched, if timestamps correct.
Playing PGS subtitles with MPC.
By doctorm in forum SubtitleReplies: 2Last Post: 28th Jan 2012, 12:25 -
Which software that can display 2 different subtitles while playing movie?
By JackyWang in forum Software PlayingReplies: 2Last Post: 29th May 2011, 07:43 -
Problem playing subtitles on some movies
By acinider in forum SubtitleReplies: 7Last Post: 29th Jan 2009, 17:06 -
Problems playing avi files with subtitles
By EPK in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2008, 21:56 -
DVD WORKSHOP 2 problem playing subtitles
By Bella in forum Newbie / General discussionsReplies: 8Last Post: 2nd Jun 2008, 11:17
