Results 1 to 10 of 10
    Dec 2010
    quebec
    is their any (free) tool (editor) that can split a double layer dvd at layer break point
    without reencoding AND keeping Ac3 and Dts audio ??
    can imgburn split it into 2 separate images ?
    the main feature is over 6G , so dvdshrink is not an option
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If DVDShrink opens the disc then DVDShrink is an option.
    ReAuthor Mode
    Dec 2010
    quebec
    well i'd rather split the 6G , so to keep original quality and not shrink it
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You don't have to shrink it, just split it in Re-author mode.
    Dec 2010
    quebec
    but .. with shring .. in re-author mode ... title 1 is 6G ...
    you suggest i manually cut it ? and find visually my cutting spot ??
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You split it at a chapter....just like 90% of the layer breaks on D/L DVDs are at a chapter point.
  7. Banned
    Freedonia
    Is there a good reason why you are determined to split this disc rather than just burn it to DL media? Verbatim still makes excellent DVD+R DL media. Just get either their DataLifePlus series (buy online - it's expensive though) or their 6x-10x DL discs and you'll get first rate media.
    Dec 2010
    quebec
    right now i'm trying dvdfab .. seams it can keep menus ,, if that doesn't work i'll re-look into shrink
  9. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Keeping menus is a whole new can of worms you may not want to open.
