Would sincerely appreciate any assistance you can provide.
I'm trying to produce a 5 minute sports highlight video. It will be a mix of clips shot on my HDC-SD10 camcorder and clips pulled from a 1.5 hour game video on DVD. I am running Corel VideoStudio Pro X4.
Immediate challenge is importing clips from the game video on DVD. I don't want to download the entire game from the DVD just to pull 5 five-second clips. Unfortunately, entire game is one "chapter" on the DVD, so I can't just import a particular chapter. I've looked through the Corel manual, but can't find anything. How can I pull short clips from one long file?
Thanks for your thoughts.
DVD Shrink in re-author mode will also let you grab sections of the video. If the video is all one title, just drag the title from the right pane to the left pane multiple times, then use the button for selecting start and end frames to keep just a small section of the title each time. If the discs aren't copy protected you should be able to open the disc directly with DVD Shrink. When you use DVD Shrink's backup funtion, saving the backup to your hard drive, each section of video should be saved as an individual vob file.
Need to record short vid clips from DVD's...Best method?
By BlueProteus in forum Capturing and VCRReplies: 15Last Post: 11th Dec 2011, 10:47 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38 -
Simple tool to make video from photos and short clips?
By largactyl in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2008, 11:45 -
Capture, Burn, Distribue in same Hour
By hap123 in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 00:18 -
Capture clips from DVD
By fleshfeast in forum Newbie / General discussionsReplies: 1Last Post: 27th Jul 2007, 03:53
