Ok so I want to edit fileproperties/information on MKV files so that i can use tags to search for the file in explorer. Like you do with mp4 files where you change the details to a file in the properties. The fileinfo I was going to put there was: genre, comments, descripton, etc.
I tried to tag the mkv files by making a a xml file and muxing it with mkvmerge, but when i do so the changes won't show up in explorer and I can't use the tags to search. I tried to use matroska shell extension, but i couldn't get it to work (don't know what it was supposed to do, but hoped it would show the tags in explorer and make them searchable).
Hi
I asked about this before.
The thread is here ---> https://forum.videohelp.com/threads/326119-%5BSOLVED%5D-How-to-tag-an-mkv-mka-file -
I have one question to the answer you got? I found out that i could show the tags in MKVinfo, but when i try to search in explorer by using the tags i created for the file i don't get any results. Isn't there a way to make the tags searchable in explorer and to show them natively in windows without having to open up a program? By searching I mean when you f.eks use size:huge to filter out all the files with 1-16 MB in the explorer searchbar. This worked with a MP4, but i haven't found out how to do this with MKV's.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 02:17 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 01:45 -
Issues Converting MKV to MP4 (could be due to damaged MKV header??)
By MohQ in forum Video ConversionReplies: 1Last Post: 1st Feb 2008, 04:10
