I use ffdshow (rev3029) with a choice of codecs for encoding,and works great(VirtualdubMOD,etc.). Problem I just put in a newer codec x264...
In the most recent versions of codecs for encoding is omitted.
For example I managed to put the new XviD Codec(1.3.2)from XMedia Recode,which is well integrated, but the newer version of the codec x264 no solution.Does anyone have an idea or some version ffdshow which has a newer codec for encoding x264,greeting...
Install the x264 vfw and it should appear in virtualdub, virtualdubmod.
Thanks for quick response...
I have tried several versions x264 VFW Codec.With the new version can not always run virtualdub.With some older versions of(virtualdub,virtualdubmod) simply crashes at the beginning of encoding,greeting...
where is ffdshow MP2 encoder at nowadays?
By wolfdogg in forum Capturing and VCRReplies: 12Last Post: 21st Jun 2012, 20:17 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
x264 with ffdshow and MPC
By Apexi in forum Newbie / General discussionsReplies: 1Last Post: 8th Sep 2009, 08:55 -
x264 encoder from x264.nl or videolan.org?
By StephanP in forum Video ConversionReplies: 1Last Post: 4th Feb 2009, 14:38 -
ffdshow, vfw and x264
By Gigaplex in forum Newbie / General discussionsReplies: 6Last Post: 21st Oct 2008, 17:02
