  1. Member gastrof's Avatar
    Sep 2004
    comfy chair
    What does it do and what does it let you do? (For example, will it record to a video file something that the player is currently running?)
    I've looked around, even on what appears to be the VLC webpage, but can't find any clearly spelled out answers.
    Thank you.
    Feb 2012
    Lyon France
    What can do VLC would need a really long answer ; I will just answer about "recording what you are playing ":
    First , you should make a recording button appear in VLC interface this way:
    In VLC go to "view" and then ,set "advanced control" ; you will get a recording button and also a snapshot button that can be useful.
    When you want to record what you are viewing, just push the recording button on ,it will become slightly blue.
    Recording will end when you push it off or at the end of the clip.VLC will make no re-encoding,so it is lossless.
    You will find a file named "vlc-record ...." in your video folder.
    (I don't Know how to change the output folder)
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Also a frame by frame advance button which is useful for discovering a telecine sequence.
    http://www.kiva.org/about
  4. Member gastrof's Avatar
    Sep 2004
    comfy chair
    Thank you guys. Very much. Managed to get it going, and fairly satisfied (and surprised, if you know what I mean) by the results.
  5. File: Open Network Stream
    Then you can record something you see on the net.
  6. Member Novice20's Avatar
    Apr 2011
    New York
    I saw the answer above but it is different on Rel 2.1.3. The red button does not turn blue when I press it so nothing shows whether it is recording. And what is the "video folder" where VLC puts the recording?
  7. Windows XP VLC recorded videos are in MY DOCUMENTS / MY VIDEOS folder.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Windows 7 recorded videos are in Libraries -> Videos (usually C:\Users\yourwindowsusername\Videos )
