Hi guys.
I've been given this file. It is 4:3 but should be 16:9.
How can I correct the ratio tag?
Thanx 4 looking.
Code:General Complete name : C:\Users\****\Desktop\10150762499648653_50184.mp4 Format : MPEG-4 Format profile : Facebook Codec ID : FACE File size : 28.9 MiB Duration : 4mn 18s Overall bit rate mode : Variable Overall bit rate : 937 Kbps Encoded date : UTC 2012-03-25 07:11:28 Tagged date : UTC 2012-03-25 07:11:28 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 4mn 18s Bit rate : 792 Kbps Maximum bit rate : 2 568 Kbps Width : 720 pixels Height : 540 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : MBAFF Bits/(Pixel*Frame) : 0.081 Stream size : 24.1 MiB (84%) Writing library : x264 core 116 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=tff / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=125 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=792 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=951 / vbv_bufsize=3963 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2012-03-25 07:11:28 Tagged date : UTC 2012-03-25 07:11:28 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 4mn 18s Bit rate mode : Variable Bit rate : 150 Kbps Maximum bit rate : 175 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 4.60 MiB (16%) Title : /tmp/tmp6CXnhx/10150762499648653.vob_audio.aac - Imported with GPAC 0.4.6-DEV-rev3544 Encoded date : UTC 2012-03-25 07:11:28 Tagged date : UTC 2012-03-25 07:11:28
Thanx for replying.
I'm using Namb but there doesn't seem to be a setting for the aspect ratio?
Encoded in Handbrake Aspect Ratio Incorrect in Roku
By douga in forum Video ConversionReplies: 7Last Post: 1st Jul 2011, 08:41 -
Converting for play in XBox 360 results in incorrect aspect ratio
By Mule52 in forum Video ConversionReplies: 5Last Post: 11th Apr 2011, 21:12 -
Aspect ratio incorrect when playing converted mp4 file on xbox 360
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 31st Aug 2009, 13:52 -
mp4 incorrect aspect ratio?
By iThinkYouBrokeIt in forum Newbie / General discussionsReplies: 4Last Post: 16th May 2008, 06:34 -
Can't enable CLEV-2 with PowerDVD 7 ultra/aspect ratio incorrect
By timbop37 in forum Software PlayingReplies: 0Last Post: 15th Jan 2008, 05:56
