Hi there
I use MeGUI for encoding, and I wanted to know if it's possible to manually add QTGMC as a Deinterlacer option in the drop down menu for avisynth script creator. Rather than me manually typing stuff in and creating an .avs, I could just open the .d2v in avisynth script creator, choose interlaced, the field order, and then choose QTGMC.
Is it possible to do that? If so, how?
Thanks in advance.
Refer
http://forum.doom9.org/showthread.php?p=841444#post841444
Look at the last part of that post under AviSynth templates
Using Avisynth MT with QTGMC
By agni451 in forum Video ConversionReplies: 11Last Post: 15th May 2014, 07:37 -
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 16:57 -
help with avisynth script to remove scratches or drop outs
By LSchafroth in forum RestorationReplies: 11Last Post: 1st Jan 2011, 12:09 -
Hardcoding Subtitles using AviSynth Creator and MeGUI
By DannyN in forum SubtitleReplies: 3Last Post: 3rd Jan 2010, 10:52 -
AviSynth - Add specific Chapters timecodes to your script
By imager in forum EditingReplies: 2Last Post: 26th Dec 2009, 07:25
