Can I change region code for Panasonic DMP-BDT210P?
I found this topic: https://forum.videohelp.com/threads/337588-to-change-region-code-panasonic-DMP-BDT110 and this info: http://www.firmwareinfo.com/viewtopic.php?f=38&t=4#advfeatures
Does is work for my model? I have the original Panasonic remote but being in the home page and trying these codes nothing changes (it doesn't restart as mentioned)
If you want to use the remote control codes from firmwareinfo.com for changing the DVD and Blu-ray regions of your DMP-BDT210, you need to install their enhanced firmware first !
http://www.firmwareinfo.com/viewtopic.php?f=49&t=94
Hope this helps
to change region code panasonic DMP-BDT110
By elprofesor in forum DVD & Blu-ray PlayersReplies: 10Last Post: 26th Feb 2014, 19:46 -
How to unlock region for Panasonic DMP-BD605 Blu-Ray Player
By Ova in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Nov 2011, 06:51 -
cannot change region code from 1 to 2
By decocal in forum Software PlayingReplies: 6Last Post: 16th Oct 2009, 05:27 -
Help ! Panasonic BD-60 UNLOCK DVD region code (Region 1)
By aexp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Sep 2009, 11:24 -
I need to change the region code for PANASONIC DMR-EZ485V
By sIRKAMUS in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Sep 2009, 03:24
