I need a way to deal with HD video. I have an HD camcorder with plenty of MTS files. I also have a Windows Media Center with multiple XBOX's as Media Extenders. I have 1 BluRay player, but no burner.
I am an IT guy, but am a novice at video format/encoding.
I want to be able to keep HD quality on my HD video but I need it to be able to play in my WMC/WME and be smaller in space. I tried dozens of apps to convert the MTS files and then combine them from many files to 1, but nothing I tried seemed to work.
On a side note, on my WMC I have a bunch of DVD's stored in VOB format, but I am using handbrake to change them into M4V with H264. Does that sound like a good idea to save space, retain quality, and make them playable on WMC and XBOX as Media Extenders?
I would like to know what kind of solution to use for these videos/movies and the software I can use to do it. I would rather not spend a ton on the software, but I am frustrated and willing to pay something for it. I would like to be able to use 1 piece of software to do it, but I am open to any of your suggestions.
DFI LanParty NF4 SLI-DR
AMD 64 x2 4400+ Toledo
thermalright xp-90 w/arctic silver
2GB (4x512) Ocz EL VX DDR500
Asus 7800GTX 256mb PCI-E x16
Hitachi SATAII 2x160GB RAID 0
OCZ 600w GamerXtreme
Audigy 2 ZS Gamer
Plextor PX-740a DL DVDRW -
Try this (it will only join clips - no fancy transitions):
https://forum.videohelp.com/threads/309674-How-to-merge-multiple-mts-files-%28canon-HF%...ingle-mts-file
Is there something wrong with the conversions from Handbrake? If they work and look good to you, then it sounds like a success.
You could try (14 day trial so nothing lost!):
http://tmpgenc.pegasys-inc.com/en/product/tms.htmlLast edited by transporterfan; 24th Mar 2012 at 19:15.
Audigy 2 ZS Gamer
On a side note, if I get a BluRay, whats the best way to store it the way I described above?
Audigy 2 ZS Gamer
You could try these, hopefully it wont conflict with the xbox setup you have.
https://forum.videohelp.com/threads/310591-MTS-Joiner
https://www.videohelp.com/tools/multiAVCHDLast edited by transporterfan; 25th Mar 2012 at 14:25.
I have tried multiAVCD but it does not seem to work for me. Although I am not 100% sure which format to use for output, I have tried several and each one of them fails. The MTS Joiner loks like it requires VOB2MPG Pro. I have not tried that yet because it has a price to buy it.
Like I said, I am willing to pay for a single piece of software to do everything I need, if I can find a good one.DFI LanParty NF4 SLI-DR
Audigy 2 ZS Gamer
HELP!!! Can't handle home video..........
By George Bazeley in forum Newbie / General discussionsReplies: 17Last Post: 17th Oct 2011, 10:23 -
Which video players can handle DivX5 files the best?
By True Colors in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2011, 10:06 -
Looking for BD Player that can handle video from USB/HD, and NetFlix.
By Huh...What? in forum DVD & Blu-ray PlayersReplies: 5Last Post: 19th Jul 2010, 11:28 -
How do presets handle video...
By bsuska in forum Video ConversionReplies: 2Last Post: 23rd Dec 2009, 09:11 -
Is there a video card that can handle both: gaming & video editing?
By randyannie in forum Newbie / General discussionsReplies: 11Last Post: 20th May 2007, 15:50
