Results 1 to 17 of 17
  1. Member deepcut's Avatar
    Nov 2011
    London, UK.
    I used to use this, then it wasn't free, now it's free again !
    It's great for VCD's which i do for The Empress so she can watch crap tv in low quality
    Just google totally free burner, it's from sabsoft.
  2. Member deepcut's Avatar
    Nov 2011
    London, UK.
    Yes but you can decline all the adware and it still installs for free ?
  3. Member Cornucopia's Avatar
    I MUCH prefer ImgBurn. It's one of the best, if not THE best, out there, and has been (and probably always will be) totally free.
    I donated to it 'cuz it's so good that I wanted to support it, but that was just my feelings (since I use and recommend it so much).
  4. Member deepcut's Avatar
    Nov 2011
    London, UK.
    Yes i use imgburn for everything apart from VCD, which i use totally free burner for, after using freemake to convert a video file to VCD format.
    Mar 2011
    Nova Scotia, Canada
    Imgburn for me too.
    I will not use adware anymore unless I have a very, very good reason to want the software. I've seen too many decent free programs turned into adware that was crap. Pretty interfaces that don't seem to be connected to much of anything, poor function, codec crap ...
    Actually I don`t think most of these people even care if you ever use the program. As long as they get their hit rate of whatever percentage of people are dumb enough to install whatever crap search bar and get paid, they`re happy.
  6. Right on Hoser!
  7. Banned
    Freedonia
    Remember, deepcut put a question mark at the end of his post, so technically speaking neither us nor him know if you actually can install this burner for free and decline the adware
    But on less critical grammatical note, I'm really not getting the point of the recommendation in the first place when in his 3rd post in this thread he says he basically uses ImgBurn anyway for everything except VCD burning.
  8. Originally Posted by Hoser Rob View Post
    You do realize that ImgBurn is adware (despite it not being labelled as such in "Tools" here) -
  9. Member deepcut's Avatar
    Nov 2011
    London, UK.
    Well, fortunately lots of adware gives you the option to decline.
    I wasn't recommending TFB in place of imgburn, but it's a simple, lightweight program that performs the simpler CD/DVD-related tasks, like burning audio CD's, and it's a free VCD burner.
    I just uninstalled then reinstalled TFB and you get the option to decline ad offers.
  10. Originally Posted by chowmein View Post
    "Back of the net" as they say
  11. Member Cornucopia's Avatar
    I would think anyone who wanted to exercise even a smattering of control over their computer would do "customized" installs, so the option or not installing that other stuff when installing Imgburn is a simple and PERMANENT no-brainer. True adware doesn't really "go away" when you ask it to.
    Btw, Imgburn can also correctly do VCDs, so I don't see the need for resorting to an alternative.
  12. Originally Posted by Cornucopia View Post
    Well maybe the Tools section here needs a concise definition of exactly what constitutes "adware".
    Mar 2011
    Nova Scotia, Canada
    I will not use adware anymore unless I have a very, very good reason to want the software. ...
    [Attachment 11593 - Click to enlarge]
    Note I did say "unless I have a very, very good reason to want the software".
    ImgBurn qualifies. It has many recommendations from people who clearly know what the hell they're talking about.
    That's a very short list.
  14. Originally Posted by Hoser Rob View Post
    I'm not knocking Imgburn
  15. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    Thanks for the heads up. I like to know that their are free alternatives out there in case something changes with the software I'm using.
    I use Imgburn and BurnAware free. I had been using Imgburn exclusively for a while after weaning myself off Nero but found a situation that made me look for something else hence... BurnAware free. When I started burning HD video to udf 2.5 on DVDRW, Imgburn insisted on doing a full format of the disc every time I used a new one. Old recycled discs previously burned with udf 1.02 didn't have to go through that extra process. This really slowed down the burn time. BurnAware free does it on the fly so burn speed is close to the disc's max rating.
    There's not much to do but then I can't do much anyway.
  16. Member Cornucopia's Avatar
    I bet that LightningUK could add that feature into Imgburn (if it isn't already hidden in there somewhere).
