Hi there
I am wanting to encode 1 of my dvd's into mkv/mp4 format, and I'm not sure which CRF to go for, so I've done a partial encode in CRF 18 & CRF 20, and I now want to do a side by side video comparison using AvsP (I've been told this is possible)
How can I do this exactly?
Both of the files are in mp4 h264 format.
I was told to try this script below but it gives me errors (Will add in what the exact error is, I am just reproducing the script now with 2 mp4 files to bring up the error again)
a=ffvideosource("path to CRF18.mkv")
b=ffvideosource("path to CRF20.mkv")
interleave(a,b)
spline36resize(converttorgb,ffsar>1?round(width*ff sar):width,ffsar<1?round(height/ffsar):height)
obviously I changed the paths to the proper paths for the 2 videos.
Hope someone is able to help please.
If you need any further info such as what version of Avisynth I have, MeGUI, Windows etc, just ask.
Many Thanks
Sim
Results 1 to 16 of 16
StackHorizontal, or StackVertical
Code:a=ffvideosource("PATH\CRF18.mkv") b=ffvideosource("PATH\CRF20.mkv") StackHorizontal(a,b) -
Thanks for the quick reply.
I've just tried as above, and the error is:-
Script error: there is no function named "ffvideosource" (New File, line 1) -
Either load ffms2.dll with LoadPlugin, or place the .dll in plugins folder to autoload
http://code.google.com/p/ffmpegsource/ -
Okay, it now looks like this:-
LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\ffms2-x64.dll")
a=ffvideosource("D:\Sample 1 Clever Anamorphic CRF18.mp4")
b=ffvideosource("D:\Sample 1 Non Anamorphic CRF18.mp4")
But I am getting an error:-
LoadPlugin: unable to load "C:\Program Files (x86)\AviSynth 2.5\plugins\ffms2-x64.dll"
Nevermind, I tried the ffms2.dll and it works now, thanks very much!
What if I wanted to compare 2 videos which are different resolutions, ie. anamorphic & non-anamorphic.
the anamorphic came out at 720x352 and the non-anamorphic 720x360
The source of the video has mixed scenes, the source is 4:3 but this particular scene I am looking at had a large amount of black bars at the top & bottom (megui cropped it with settings of 60 both sides, if that means anything to you), does that mean the particular scene was shot in 16:9 but is appearing in 4:3 so there are black bars? Am I correct or am I way off?
You have to resize one to fit the other, just like a media player would
The comparison isn't necessarily valid, because the method of resizing can skew the results
But are you sure those resolutions are correct? . Use mediainfo. Maybe they are just cropped or resized differently? In that case use AddBorders to pad -
in MeGUI, I set Clever Anamorphic to "overcrop to achieve mod16" so that's why there's a difference in resolution, I think.
In terms of this 'scene' in the DVD, because there are big black borders at the top & bottom am I right in thinking it's a 16:9 widescreen, and because the dvd source is 4:3 its showing with black borders like it is? -
Hi Cornucopia
If it was indeed a 16:9 anamorphic, but put on the 4:3 dvd, how should I encode it in terms of Input DAR and also should I choose clever anamorphic encoding? :O -
What is telling you the original dvd truly was 4:3? Megui?
I don't like auto features like "clever anamorphic", prefering to do my own calculations & manual settings adjustment, so i don'really run into problems like that very often. It would take some doing to track down where the problem lies.
Scott -
You can load different scripts in different tabs and then flick back and forth between them (hit ctrl-TAB). This is is a very good way to see small differences between frames, to compare blurring, etc.
You can just get one script, double click on the tab to duplicate it, then modify the new tab.
The frames in each tab are synchronised.
Is the panasonic dmres46v a seudo svhs side-by-side player/recorder?
By yoda313 in forum RestorationReplies: 8Last Post: 17th May 2010, 08:09 -
Video Stream Side-By-Side
By maza1967 in forum Video Streaming DownloadingReplies: 3Last Post: 10th Mar 2010, 10:31 -
Merge 2 FLV video files side by side
By zsuppguy in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2010, 16:58 -
compareing 2 videos side by side in same video. (sugestions)
By tessa101 in forum EditingReplies: 4Last Post: 9th Jan 2009, 02:36 -
Vegas 6 Side by Side Video
By CobraStrike4 in forum EditingReplies: 1Last Post: 21st May 2008, 16:23
