Hi guys,
I converted some files from MKV to MP4. I noticed with mediainfo, that the MKV files had 5957 kbps. The MP4 files have 7360 kbps.
Does the higher bitrate decrease the quality? Or does it just increase the file-size?
Thanks for your help!
Tex
Ah ok thx for your fast reply! Well I do it with Audials 9. I think the results are ok, what do you think about this product?
And are the default settings of mkvtomp4 good enough for Apple TV? I ask because when I go to the audio settings, the defaults are AAC 2.0 Quality 0,55. Why 0,55 and not 1,0?Last edited by tex4ever; 24th Mar 2012 at 03:42.
In the case of AAC most programs default to Q0.50, which is supposed to be where AAC is "transparent". Why your program defaults to Q0.55 I'm not sure as I've never used it. Personally I just encode everything using Q0.50
As suggested it might pay to try using a tool to extract the existing audio/video from the MKV and save it as an MP4. No re-encoding required so no quality loss. Whether it'll work depends on whether the MKV contains audio/video the MP4 container supports (h264 and AAC is fine). Whether it'll play on a particular device depends on the settings used when originally encoding the video (MKV) and what your player supports. YAMB is another tool which will open MKVs and save them as MP4s.Last edited by hello_hello; 24th Mar 2012 at 06:51.
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
MKV Compression to a smaller MKV or MP4
By THRobinson in forum Video ConversionReplies: 9Last Post: 20th Jul 2018, 10:56 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
muxing .264 stream to .mkv, or to .mp4 first, an then to .mkv ?
By codemaster in forum Video ConversionReplies: 2Last Post: 20th Sep 2011, 20:50 -
Issues Converting MKV to MP4 (could be due to damaged MKV header??)
By MohQ in forum Video ConversionReplies: 1Last Post: 1st Feb 2008, 03:10
