I am pretty new the field of video editing. Recently, a video of me speaking has been recorded, and there is a powerpoint that goes along with this video. How can I add slides at various intervals at full screen so the viewer can see the powerpoint I am working off of, without interrupting the flow of the audio, and transitioning back and forth between me speaking the the powerpoint slides. What program is best able to do this, and where can I learn how to do it properly![]()
Any decent pro, prosumer or even hobbyist NLE (non-linear editor) will be able to do this. It can either be done as single-track A/B insert edit or using 2 tracks you drop in and overlay the ppt slides (pix) on top of the video background. Depends mainly on which way you're familiar/comfortable working.
Most nle apps work very similarly, so learning about EDITING in general should transfer from 1 app to another. Note that there really are NOT any totally free, bug-free, easy & feature-packed nle apps. You could probably get by with WMM, but you might be fightinng an uphill battle at times. Offhand, I'd recommend Vegas Movie Studio Platinum, as it is fairly easy to get started with and will grow with you. The pdf manual that comes with it might also be enough to get you going for the project you have in mind.
ScottLast edited by Cornucopia; 24th Mar 2012 at 00:45.
Yeah, I tried using Windows Movie Maker, and it wouldn't let me do anything except split the movie in pieces and insert the slides, which wasn't working the way it was supposed to. The tools in Windows Movie Maker are extremely limited.
EDIT: Nevermind the question. I just saw the answer about the NLE. Thanks.
Creating a 2 minute video
By mgk103 in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 09:26 -
Creating Video screenshot
By tuanvn.2007 in forum Video Streaming DownloadingReplies: 4Last Post: 21st Sep 2008, 09:37 -
Creating a analglyph 3D intro video
By Shilar in forum EditingReplies: 4Last Post: 5th Aug 2008, 04:21 -
Creating video tutorials
By jwfc in forum EditingReplies: 5Last Post: 19th Oct 2007, 18:04 -
After creating a video CD I only get the menu to appear...help
By dave4500 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jun 2007, 01:23
