I just set up my Azden WMS-Pro wireless microphone. I have two video cameras Canon VIXIA M41 and a kodak play touch.
I just did test videos. My voice is hardly audible when I use this system. I hear my voice faintly with the ear bud when recording. I am only 5-10 feet away from the camera so distance is not the issue.When uploaded onto my computer there is hardly any voice.
I have checked my volume controls on cameras and computers& I am using premier elements for editing.
Any ideas? Do you think I have a bad microphone? This unit runs on 9V batteries could they be low even though they are new?
thanks in advance for any comments.
	It's possible the batteries are the problem but I think it's an impedance issue, your cameras might require lower impedance mics.
 http://www.mediacollege.com/audio/microphones/impedance.html
 Check the receiver or camera to see if it has an impedance selector.Last edited by MOVIEGEEK; 22nd Mar 2012 at 19:59.
	Thank you for your reply,
 the microphone has and impedance of 300 ohm, from your link that is low and should be good.
 I can't find any impedance information on the cameras.
 I will get new batteries in the morning and see what happens.
 Weird that the volume is almost nothing with both cameras. that makes me think it is the microphone system.
  Going wireless- what do I need?By aelfheah in forum ComputerReplies: 11Last Post: 24th Nov 2011, 16:27
  Wireless???By rico1 in forum Video Streaming DownloadingReplies: 7Last Post: 4th Sep 2010, 18:40
  Best Wireless Utility that can be used with any wireless cardBy mol3000 in forum ComputerReplies: 4Last Post: 7th Jul 2009, 13:29
  how to limit speed of users on wireless network (router-lan-wireless)By deejay.2001 in forum ComputerReplies: 5Last Post: 3rd Nov 2007, 00:56
  USB Wireless lan stronger than Internal wireless?By Super Warrior in forum ComputerReplies: 11Last Post: 7th Aug 2007, 00:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
