Hi guys,
I was trying to backup a couple of discs and the only software that seems to work is DVDFab.
I made a Full DVD copy, the original DVD is more than 6GBs, the output is a little bit more than 4GBs.
What am I missing?
Results 1 to 11 of 11
Some dvds will show a bigger size because of the dvd encryption/arccos protection.
But you can also try backup the anydvd and bdlot iso master. -
@transporterfan
It was set to DVD5 when I ripped the first DVD but I switched to DVD9 for the second one.
Nothing changed.
BTW, does this mean that DVDFab can shrink too?
@Baldrick
A bigger size of that amount? Some GBs?
As for the software, I went for my usual set at first (RipIt4Me+DVDDecrypter) but it got stuck and entered an endless "Inserting Dummy Sectors" routine, so I gave up.
I don't have AnyDVD on my pc, BDlot DVD ISO Master failed too. -
Yes. http://www.dvdfab.com/tutorial/DVD-to-DVD-Full-Disc
What size was reported for the original second disc? -
Yes indeed. In fact, we've had a report where because of this bad sector type copy protection (this is what you have based on the RipIt4Me output you reported) the DVD claimed to hold something like 90 GB, which is more than even dual layer BD can hold. So yes, it's certainly possible that the DVD is claiming to hold 6 GB when in fact it's actually single layer size. Claiming to hold more data than actually exists is an attempt to trick some conversion programs into doing massive compression when such is actually not necessary.
Although many on this forum deride this combination as being out-of-date, as you have experienced--and I can confirm--, it is often STILL very useful.
My further experience: When this combination won't work (and yet doesn't "hang" like you described, which is sometimes the case), you will likely see a notice that "will require 6% compression to fit on a DVD5", or some VERY low number, meaning impossibly high compression needed. THAT'S your clue that that you have a complex protection scheme and that DVDFab (to decrypt), followed by DVDShrink (to, well, shrink) is the likely pairing for success. Had that happen to me just this week. -
@transporterfan
the second DVD is 6114MB (according to DVDFab), I set "DVD9", the output is 4,19GB.
As for the guide you linked, it's what I did (except specify the Region Code and the burning).
@jman98
Really? Never heard of that.
I learned something.
Anyway, according to DVDFab the discs are dual-layer.
@CobraPilot
I don't know, maybe it is out-of-date but as far as it works I don't see a reason to change.
The p.i.t.n. is when it doesn't work.
Let me get this straight: does 6% mean it will be compressed by 94%?you will likely see a notice that "will require 6% compression to fit on a DVD5"
@tarzan54
Thanks to you too.
I usually stick to free software but just f.m.i., if I buy a "payware" the periodic updates are free or do I have to pay each time? -
Yes, that "6%" equates to MASSIVE (94%) compression because the protection scheme tricks some software to interpret there are many times more data on the disc than is even possible. jman98 explains that above. DVDFab is seldom tricked by these schemes although new ones appear regularly, typically followed by an update of DVDFab.Instant Martian: @CobraPilot
Let me get this straight: does 6% mean it will be compressed by 94%? -
If you followed the guide, then I have to assume it is some protection mechanism.@transporterfan
Try updating.
Specific Question Regarding DVDFab
By charmedlife417 in forum DVD RippingReplies: 7Last Post: 9th Nov 2011, 07:14 -
DVDFab Question
By Rjupiter in forum DVD RippingReplies: 2Last Post: 2nd Dec 2008, 00:37 -
Dvdfab question
By nugent in forum DVD RippingReplies: 2Last Post: 26th Mar 2008, 06:37 -
DVDFab Question
By magicseven in forum Authoring (DVD)Replies: 1Last Post: 23rd Jan 2008, 11:15 -
Question on dvdfab platnium
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2007, 11:40
