Hello I have a black magic intensity pro capture card. I own the new xbox 360 slim and it has 1 hdmi slot. I play on a computer monitor which has a DVI and a VGA hook up. I use a DVI to hdmi cable to play on my Xbox 360. So enable to capture video and play Xbox do I need a Hdmi y splitter cable (to hook up my monitor and 1 for the capture card). Will this all work before I buy all this? Or would I also need to buy a VGA to hdmi? Thank you.
Passive splitter cables lower the HDMI signal strength by half, which can affect the picture. To provide a full-strength signal to a monitor and capture device, you need a powered HDMI splitter, like this: http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10113&cs_id=1011306&p_id=...seq=1&format=2
Using a monitor, it is likely that the only captures that you can make will be 720p. Monitors don't understand what to do with interlaced video (1080i and 480i are interlaced). Also, monitors often can operate only at either 50Hz or 60Hz, so video that uses other frame rates probably won't work either. ...and 720p is unlikely to look good on the monitor, because generally monitors don't upscale as competently as a TV, and only video at their native resolution looks good.
Given what another forum member has said about his HD game capture setup, if you plan on making HD captures, you will need to check to be sure you have a computer powerful enough to handle encoding on the fly, and if you plan to capture using a lossless video format, you will need a raid array to contain the gigantic capture files and avoid dropped frames.Last edited by usually_quiet; 22nd Mar 2012 at 18:56.
Black Magic Intensity Pro: Issue with xbox 360 settings
By dreamboss in forum Capturing and VCRReplies: 2Last Post: 14th Mar 2012, 20:50 -
problems hooking xbox 360 thru Intensity Pro card, to monitor
By rnramapage in forum Capturing and VCRReplies: 1Last Post: 29th Jun 2011, 15:21 -
Black Magic Intensity Pro + PS3 + One monitor
By Utorak in forum Capturing and VCRReplies: 1Last Post: 31st Jan 2011, 15:15 -
Black magic intensity pro xbox 360 help
By razerpro in forum Capturing and VCRReplies: 5Last Post: 25th Jun 2010, 11:20 -
No audio when capturing from 360 via Black Magic Intensity(hdmi)
By ercdill in forum Capturing and VCRReplies: 5Last Post: 29th Dec 2008, 14:24
