  1. I burned The Sitter.
    I used AnyDVD to take the copyright protection off.
    When I go to play the movie in my blu ray player, it starts to play then a screen comes up saying that I need to update my blu ray player.
    I have tried the blu ray on 2 different players.
    What should I do to get the movie to work?????
  2. Banned
    Freedonia
    I can't find The Sitter on a list of Cinavia protected discs, so that may not be it. This was released just this week in the USA so you may have to wait for AnyDVD to be updated to be fully able to rip and play this title. I have AnyDVD and while I like it, they are a little slow on updates.
    Sep 2011
    Try Idea DVD Copy, It has a free trail period, I have used it several times when DVDfab and Anydvd wouldn't work, For some reason they have updates faster for new copy protection.
  4. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    I would try DVDFab.....
    I have had more problems with Anydvd and don't even bother with it anymore...
    Slow on updates is an understatement.
    They have options that have never worked for me and made the final product useless in quite a few other popular/common
    software.
    Idea DVD Copy is not even something i would even bother with.
    I have never had any problem's with DVDFab when ripping Bluray's, except with "The Three Musketeers" and that was only because i was using a version that was like 3 versions old, updated and no problem.
