Hi all,
I have this damaged/corrupted file recorded by Sony PMW-EX1.
Has anyone had the same problem in the past? File is MP4 here's spec from other clean recordings:
Format : MPEG-4
Commercial name : XDCAM EX 35
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 53.1 MiB
Duration : 12s 480ms
Overall bit rate : 35.7 Mbps
Encoded date : UTC 2012-03-14 17:13:42
Tagged date : UTC 2012-03-14 17:13:42
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Codec ID : 61
Bit rate mode : Variable
Bit rate : 34.0 Mbps
Maximum bit rate : 35.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.656
Stream size : 50.6 MiB (95%)
Language : English
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Codec ID : twos
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 2.29 MiB (4%)
Language : English
..while the other file just reports:
Format : MPEG-4
Codec ID : mp42
File size : 320 MiB
...and nothing more.
Do you know any good software (payware aswell) to restore that important clip?
Thank you in advance
elmuz
I use Video repair tool. It has worked for most corrupt files. Try first the free trial and see if it works at all, you choose the corrupt file and a working sample.
Mobile phone format / PMW EX1
By B-Twien Bytes in forum Latest Video NewsReplies: 2Last Post: 18th Oct 2011, 20:09 -
White balance sony pmw-ex1
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 9th Mar 2011, 05:14 -
Wedding Videography Sony HDC 900 or Sony PMW EX3 ? Tapes?
By mek in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2010, 14:35 -
Sony PMW-EX1 and use of ND-filter
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 12th Mar 2009, 06:11 -
question about how to recover corrupted photos
By jimdagys in forum Newbie / General discussionsReplies: 6Last Post: 3rd Mar 2008, 08:57
