I have some LPs I wish to record and archive at 88/24 or 96/24 for optimum sound quality.
Is it possible to make 2-channel DTS CDs from these? I know you can make 44.1khz 5.1 DTS CDs but is stereo DTS an option? And can a DTS-CD accept 96/24 or only 44/16?
Hi there.
Technically, yes it is possible to create a "normal" stereo DTS-AudioCD, however it would be a waste of bitrate + time + effort
Do the math:
Uncompressed "RedBook Audio" = 1411kbps
"Normal" DTS-CD = 1234.8kbps --- and 2.0 DTS @ 44.1kHz sounds "lossless" at 512kbps
As for the UN-common
DTS-CDs, afaik, these are stereo-only
, BUT also must be sampled at 88.2kHz
Besides, ¿ are you sure your receiver does support such type of DTS streams ?
What about burning the 98/24 LPCM files to a DVD-R disc, would that create a DVD Audio disc? Can you make a menu for choosing playback of tracks?
Only if you author those files as a compliant AUDIO_TS folder:
http://dvd-audio.sourceforge.net/spec/index.shtml
Yes, but you'd have to use an appropriate authoring software.Can you make a menu for choosing playback of tracks?
Apparently the dvda-author package already supports some basic menus:
http://dvd-audio.sourceforge.net/advanced.shtml
However I really don't know if the result would be "acceptable" when compared to a commercial software like DiscWelder Chrome
FWIW, I prefer N0 menus plus the "boring"
foobar2000 interface
Sorry, I meant a DVD-Video disc but with audio playing over still images (menus). In DVD Lab Pro, for example?
Still pics with audio are 100% OK for DVD-lab PRO.
Just make sure your hardware player does have a decent Digital2Analog converter, of course
Sure
So just to be sure, still pics with 96/24 audio are fine for DVD Lab Pro too?
PCM is huge, is there a lossless codec I can use to compress them? -
2.0 @ 96kHz @ 24-bits = 4608kbps
Lossless compression, only for DVD-Audio,
BUT you don't want DVD-Audio, right?
Maybe you'd better try an ** audio-only Blu-Ray **
--- tons of disc space, and also lossless compression
(TrueHD or DTS-HD Master Audio)
The choice is yours, don't be late
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
Creating a Blu-ray Theater Demo Disc w/ DTS-HD, TrueHD & LPCM
By scubasteve2365 in forum Authoring (Blu-ray)Replies: 6Last Post: 29th Jan 2011, 10:00 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 07:06
