Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
Results 1 to 1 of 1
  1. I am looking for a Blue Ray DVD Player that I can hook up an USB Drive or an USB Hard Drive to, in order to play my backed up movies. I believe most of my movies are in the avi format.
    Which one do you recommend. Something not to expensive preferably.
    Don't know if I should include this part here or not, but I will cause my main question is above, but I would also like to know if that is the way most of you are now playing your backed up AVI files. Just wondering what my other options are. I know burning a disc is; as either an avi or dvd.
    Thank you for all your help.
