Hello
How can I transfer a HD recording from this terminal to a PC?
http://www.cdfaudio.com/Videotron.html
Thank you in advance for your advices![]()
Doubtful.
Have you tried any of the connections on the unit? Are there any computer-friendly connections on the unit? -
Unfortunately, I don't have the device in front of me.. I was asked by a friend of mine
There is an USB on the front.. and probably a HDMI port on the back.. -
If this is a cable box it is probably like 95% of most cable boxes....copy protected to hell and back. The only way out is analog, real-time capturing.
That is a picture of a Scientific Atlanta 8300 DVR. The recordings on a cableDVR's hard drive are encrypted and since it's for a Canadian cable service, it is unlikely that there is any way to transfer the recordings to a computer. In the US, the FCC mandates FireWire (IEEE 1394) connections on HD cable boxes that can sometimes (but not always) be used to transfer recordings during playback, but Canada imposes fewer regulations on cable operators and has no such requirement. There is a USB port in front, but it is reserved for a future use and inactive.
Your only option is to get an HD capture device and re-record while playing the recording. The Hauppauge HD PVR or Hauppauge Colossus can record 1080i, 720p, 480p or 480i from the cable box's analog component video output and stereo or 5.1 audio via optical S/PDIF.Last edited by usually_quiet; 21st Mar 2012 at 10:54.
Thank you for the infos hech54 and usually_quiet. My friend would have to do with his DVD recorder then..
DV transfer what do you think
By mikesbytes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 1st Apr 2011, 21:31 -
Pinnacle Transfer Capture card not recording footage of my N64?
By chibirobo1 in forum Video Streaming DownloadingReplies: 6Last Post: 28th Mar 2011, 22:03 -
Recording a better copy of an old recording.
By cyber-junkie in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 16:48 -
WinTV and Videotron/Illico
By mtlitguy in forum Capturing and VCRReplies: 2Last Post: 15th Mar 2009, 08:49 -
HVR-1600 with illico Videotron
By micboule in forum Capturing and VCRReplies: 0Last Post: 16th Oct 2007, 20:42
