I have some 500MB of ISO files made with dvd shrink on my old P4 PC, my TV is Samsung D6000 smart set, which is wired to my hub (ethernet over power). TV and PC are in separate rooms and on the same LAN. I'd like to be able to browse/playback those films on TV. The PC overheats very easy, I can not run any conversion on it. So, question - what h/w would video gurus recommend to use in this situation? Budget is roughly $100.
Regards
not sure if this is the best option ,but check the Western Digital TV Live(refurb for $59) or ASUS O!Play
$20 off w/ promo code 24HRSALE321E
http://216.52.208.185/Product/Product.aspx?nm_mc=AFC-TechBargains&cm_mmc=AFC-TechBarga...82E16822136997Last edited by MJA; 21st Mar 2012 at 09:42.
thanks. I see wd passport devices are quite inexpensive.
will I be able to put my ISOs on it?
and I can not find out if my samsung D6000 is smart enough to play ISO?
Recommend a router.
By Poppa_Meth in forum ComputerReplies: 7Last Post: 6th Mar 2011, 19:46 -
What burner would you recommend?
By taboo in forum MediaReplies: 33Last Post: 5th Jul 2008, 12:01 -
what would you recommend?
By mopar339 in forum MacReplies: 2Last Post: 16th Feb 2008, 08:36 -
Recommend an all-in-one.
By Poppa_Meth in forum ComputerReplies: 12Last Post: 9th Feb 2008, 10:41 -
can anyone recommend TV Tuner?
By mvp in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2007, 07:53
