  1. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    When I compress an MPEG2 video file to an RAR file....I normally only get a few MB of savings. I understand that. That is normal.
    So how come I just RAR'd a 202MB video file and it came out to 85MB?
    I thought to myself....THAT CAN'T BE RIGHT....so I uncompressed it and presto...there was the 202MB video file in it's full glory.
    WTF is going on?
  2. The last step of MPEG compression is a lossless entropy encoding much like archive programs use. That's why you don't get much more compression when you archive MPEG video. Are you sure the file you just compressed was MPEG encoded? Did it have a PCM audio track?
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Format : MPEG-PS
    File size : 210 MiB
    Duration : 4mn 16s
    Overall bit rate : 6 874 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 4:3
    Frame rate : 25.000 fps
    Standard : PAL
    Scan type : Interlaced
    Scan order : Top Field First
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    And here is the RAR file:
    86.2 MB (90,479,972 bytes)
    Today, March 20, 2012, 7:23:15 PM
  5. Member Cornucopia's Avatar
    I've seen plenty of lossily-compressed media encodes that, when re-archived in a lossless compression format (zip, rar, sit, 7z, etc) will BLOAT. Partly because the resulting byte sequence of the lossily-encoded media file has pretty much ALL of its redundancy taken out of it, and redundancy is the thing that gives lossless archive compression its power...
