I am getting a camera but it only outputs h.264 in .mov format.
I want them in m2ts.
Without evidence to the contrary I would say yes. It would be the first app I would try. It handles .mov.
I have a Cannon T3, that shots movies in AVC/H264 in a Mov container.
I just did what you asked, as a test to see if it works or not.
When I loaded the mov into tsMuxeR the video loaded but not the audio. The audio in the Mov is single channel PCM. I then loaded the mov in Audacity which demuxed out the audio and saved it as two channel AC3 and wav. (BTW I have FFmpeg library loaded in Audacity) tsMuxer then accepted the AC3 and two channel wav.
I muxed the audio and video as TS, M2TS and a Blu-Ray disk, all three played just fine using PotPlayer.
So in short yes it will work.Last edited by ANK; 20th Mar 2012 at 04:58. Reason: addition
tsMuxer and joining m2ts files
By fkasparek in forum Blu-ray RippingReplies: 13Last Post: 12th Jun 2014, 12:07 -
I can not add .m2ts files into TSMuxer
By yaoyao0204 in forum Blu-ray RippingReplies: 2Last Post: 25th Nov 2011, 20:00 -
Change DV stream from .mov to .dv container without reencoding
By DavidCasillas in forum MacReplies: 3Last Post: 16th Sep 2011, 02:18 -
is it possible to author a BR usig m2ts files without reencoding?
By Onceler2 in forum Authoring (Blu-ray)Replies: 6Last Post: 5th May 2010, 10:23 -
Audio drifting when merging Sony .m2ts files in tsMuxeR
By jaholmes in forum Authoring (Blu-ray)Replies: 2Last Post: 28th Sep 2009, 12:02
