I have collected some pieces of an interesting music gig, and I want to put it together in a Blu Ray disc (BD) with menu, BUT avoiding reformat or reprocess or reencode what already is a HD video that was recorded with a Kodak pocket cam.
I tried Vegas 11 and Nero, but they did not understand the format and want to re-render everything.
Is my understanding that (apart for the Quicktime envelope) what I have inside is no other than an AVC or a MP4 file, and that must be "smart rendered" by any software.
Why recompress again something that must be already ready for a authoring a BD?
If I use YAMB software to get other "envelope", Shall I be reencoding the thing?.
I am a little confused...
File Data:
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 323 MiB
Duration : 4mn 5s
Overall bit rate : 11.0 Mbps
Movie name/More : KODAK Zi8 Pocket Video Camera
Encoded date : UTC 2009-02-18 16:03:15
Tagged date : UTC 2009-02-18 16:03:15
Origin : Digital Camera
AMBA :
Video
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=15
Codec ID : avc1
Duration : 4mn 5s
Bit rate mode : Variable
Bit rate : 10.9 Mbps
Maximum bit rate : 17.7 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.175
Stream size : 319 MiB (99%)
Title : Ambarella AVC / Ambarella AVC
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 4mn 5s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -33ms
Stream size : 3.75 MiB (1%)
Title : Ambarella AAC / Ambarella AAC
Language : English
Try avchdcoder and multiavchd.
You could also try "remux" the mp4 to a ts or m2ts with tsmuxer and see if it works in your current software.
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
AutoGK question: Can I "Force IVTC" on "Hard-encoded NTSC&am
By BozQ in forum DVD RippingReplies: 11Last Post: 12th Jun 2009, 14:46 -
Set/Fix QuickTime "atoms"/"flags"?
By rumplestiltskin in forum Newbie / General discussionsReplies: 3Last Post: 22nd Sep 2008, 14:07 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45 -
TMPGEnc DVD Author 3 DivX "Smart Rendering" Bug?
By ln108 in forum Authoring (DVD)Replies: 7Last Post: 23rd Aug 2007, 12:27
