Page 2 of 2
FirstFirst 1 2
Results 31 to 39 of 39
  1. Is DirectShowSource.dll still in your AviSynth plugins folder?
  2. Originally Posted by jagabo View Post
    Lol, no, deleted it accidentally when I reinstalled the plugins.
    Now it works finally.
  3. DirectShowSource("E:\1.ts")
    QTGMC( Preset="Slow" )
    lanczos4resize(1280,720)
    I used this script, and it did double the framerate, but it appears as jerky as 25fps? Yadif script appears smooth as 50fps.
  4. Originally Posted by jiopi View Post
    Are you playing the script, or a video made from the script?
  5. Originally Posted by manono View Post
    The encoded video.
  6. Add AssumeTFF()
    AssumeTFF()
    Avisynth will assume bottom field first, unless otherwise specified . Almost always HD video is TFF
    You probably don't need to use "slow", even "faster" settings will get you 90-95% of the quality but be significantly faster
  7. Originally Posted by poisondeathray View Post
    Add AssumeTFF()
    AssumeTFF()
    Yeah, that was it.
    Now there is only what setting should I use? Filesize doesn't really matter, I have plenty of space in HDD.
    Yadif Bob 720@50p 7000kbps 2pass
    QTGMC 720@50p 9000kbps 2pass
    Slow gives me about 3fps and faster about 6fps, how much would the multithread option speed it up?
    EDIT: compared screenshots, the difference between slower and faster was miniscule. I think faster should do it.
  8. Originally Posted by jiopi View Post
    Add AssumeTFF()
    AssumeTFF()
    Yeah, that was it.
    I meant "faster" for QTGMC, not x264 encoding setting, but it could apply to that as well, it depends on the situation and rate control.
    QTGMC( Preset="faster" )
    Have a look at the instructions, there are other presets and dozens of other settings as well
    You cannot make quality comparison yadif and qtgmc at different bitrates (not a valid comparison for any quality comparison, not just deinterlacers)
    If you don't really care about exact filesize, consider using CRF encoding instead. It's 1 pass and faster. Use around 16-22 (lower values give higher bitrates , thus larger filesizes and quality). It allocates bitrate according to scene complexity - so high complexity content will get more bitrate than low complexity content - all proportional to the quality level you set. If you use CRF 0, it's lossless (huge filesizes)
  9. Originally Posted by poisondeathray View Post
    Add AssumeTFF()
    AssumeTFF()
    Yeah, that was it.
    Yeah I meant QTGMC also, I had x264 encoding in slow.
    I think I will go with this, QTGMC faster, x264 slow CFR 16.
    Thanks for the help again yall.
