Hi,
Is it ok to burn a VCD movie on a 80 min cdr and add other files just to fill up the cdr (its so a waiste of space)? Does it effect the film? Like if its still will be playable on dvd standalone and pc, quality, etc..
Thanks for ur support...
- an666a -
You can add other files with Nero and VCDImager.
It doesn't affect the film or playability.
Regards.Michael Tam
w: Morsels of Evidence -
Cyberlink's Power Director 2.0 Pro will let you throw in a mixture of stuff on a VCD disk, like a movie plus slideshow, etc. Then you watch what you want and it doesn't affect the movie itself.
Yeah, you load a ton of stuff into the program and it all appear as thumbnails, then just mix them on a filmstrip at the bottom of the screen, then burn the CD (with menus if you want). Nice program overall and easy to use but get a demo first before paying for it since it has some limitations which are driving me insane :lol:
Originally Posted by vitualis
But its good to know that about power director keffie -
You can for Nero.
After you choose to create a new VCD, you can drag and drop additional files into the filesystem.
Regards.Michael Tam
VCD with SWF files
By justdoit in forum Authoring (VCD/SVCD)Replies: 14Last Post: 28th Dec 2011, 20:45 -
890619 - convert TS to VCD compatible files.
By hamidi2 in forum VCDEasy GeneralReplies: 2Last Post: 9th Sep 2010, 17:21 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 06:50 -
Author VCD files in a to DVD Disc
By akakiami in forum Authoring (DVD)Replies: 6Last Post: 5th Jan 2009, 05:22 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 17:37
