should you ripp dvd to hard drive first or ripp right from dvdrom?
l8r.
A "DVD Rip" is an exact copy of the disc with NO compression(despite what little geeks call what they place on torrent sites).
Converting a DVD to video file is always faster from the HDD. -
I always rip from dvd to hdd. Usually with DVDfab HD decrypter. It works quite well. Set output to DVD-9 so it won't do any encoding/compression. Its encoding sucks.
Then I use handbrake or vidcoder (which is handbrake with a different GUI) to encode to mp4 or mkv. The latter if I want the subs. mkv will embed them within the output file.
Yes, it's faster to do it this way even though there's another step. The decrypting doesn't take much power. Separating the encoding (which does take power) from the optical drive speeds really things up. Optical drives are by far the slowest thing on your computer. -
You've been around here a long time to not understand what "rip" means.
https://www.videohelp.com/glossary?R#Rip
rip != convert
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Ripping Saw 6 (Saw VI) dvd, HELP!!!
By diluvian8 in forum DVD RippingReplies: 5Last Post: 27th Jan 2010, 22:45 -
Ripping a DVD
By andreltr in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2009, 09:29 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22 -
Ripping DVD'S
By bamf321123 in forum DVD RippingReplies: 3Last Post: 23rd Jun 2007, 04:57
