I download a video with has chinese subtitle in it. But i want watch it with engsub (i have the srt). So i want to remove it . I was install MKVtoolnix and do mkvinfo command tThere's (i'm using ubuntu), but there's only two tracks their (audio and video). So i try to use MKVextract-gui2 and MKVtoolnix (run with wine) but i still can't find the subtitles track.
So how can i removed it? It's really annoying cause i can't watch my engsub clearly.
Thx
	If it's hardcoded, you cannot remove it (if it's not a softsub). This means it's permanently part of the video
 You can position your english subs higher or lower on the display with your media player
 Or try to re-encode it to cover up the subs (e.g. put a black box on it so the english soft subs are displayed on the box)
	sanlocrip,please do not double post,i deleted your other thread. I think,therefore i am a hamster.
  No A/V problem with MKVToolNix and MKVExtract 1.6.4.1By lostinlodos in forum Video ConversionReplies: 7Last Post: 16th Sep 2011, 02:29
  can't find mkvextract in mkvtoolnixBy scarlac in forum MacReplies: 1Last Post: 20th Apr 2010, 10:19
  Subtitle Creator - Unable to set Default Subtitle Colors & Default ProfBy blue2 in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 23:47
  How can I find the FPS of my Sub/Idx subtitle?By reza_17173 in forum SubtitleReplies: 2Last Post: 7th Mar 2009, 09:47
  Want to use Autogk to add subtitles but can't find external subtitle optionBy godfist314 in forum SubtitleReplies: 1Last Post: 15th Jul 2008, 20:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
