geachte leden,ik heb me een multimedia schijf,wd elements play,aangekocht,dus ik kan gemonteerde filmjes van mijn pc afspelen op mijn tv via hdmi.ik bewerk mijn beelden met studio 14 van pinnacle en dit lukt goed.mijn vraag is in het venster film maken wil ik een bestand maken met zo weinig mogelijk verlies.ik vertrek dus met1080x1920 en kan dit ook weergeven via mijn media schijf.op mijn tv alleen snap ik de instelling niet in mijn montage progamma bv mpeg2 mpeg 4 door het bos zie ik de bomen niet meer.hopende op jullie deskundige hulp dank ik jullie beleefd.margeo
	We talk english here.
 Google translated:
 Honourable members, I have a multimedia disk, wd elements on, bought, so I can mount filmjes my PC play on my TV via hdmi.ik edit my images with pinnacle studio 14, and this question is in the works goed.mijn window movie I want to create a file with as little departure so verlies.ik met1080x1920 and can also view my TV via my media schijf.op only I understand the setting in my installation RANGE eg mpeg2 mpeg 4 through the woods I see meer.hopende the trees on your expert help I thank you beleefd.margeo
	Don't you just love google translate? The funniest thing is that I've seen stuff written here in English that was just as coherent.
	Hi Margeo,
 If I understand well, you say your source can already be played by the WD media player.
 Check out the specifications of your source with MediaInfo. Then use the same codec and resolution in Studio 14. It might be able to only render effects and transitions and leave everything else "as is". This would give you minimal loss of quality.
 I'm not a Pinnacle Studio 14 user but someone else can perhaps post some details on its capabilities.
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
