I am using VirtualDub to remove subtitles. Using "msu subtitle remover" filter latest beta 3.0.2.
I keep getting an error message.
The message is:
And after that VD crashes!Code:"Error opening mask file! Please make sure you specified correct spool dir"
Can anyone tell me what this means and how I can fix the problem?
Thank you
When do you get that error message??
See http://www.compression.ru/video/subtitles_removal/userguide_en.html
See also http://forums.afterdawn.com/t.cfm/f-2/error_message_in_virtualdubmod-803926/ ...exact same problem.
Help needed with MSU Subtitle Remover in VDub
By Lippy Lipstick in forum SubtitleReplies: 11Last Post: 5th Mar 2010, 08:03 -
MSU subtitle remover, the great lie!
By driva in forum Newbie / General discussionsReplies: 5Last Post: 27th Dec 2008, 19:37 -
frustrated with VDMOD and MSU sub remover
By volam in forum SubtitleReplies: 1Last Post: 7th Feb 2008, 08:45 -
VirtualDub MSU Subtitle Remover directions help
By LangleyM in forum SubtitleReplies: 4Last Post: 6th Feb 2008, 07:56 -
removing hardsubs with "msu subtitle remover"
By dnan in forum EditingReplies: 6Last Post: 13th Sep 2007, 16:43
