Hi guys can someone tell me what is right way to convert this file into something more normal it is mp4 file I guess . By the way no nle doesn't want to open it.
Here is mediainfo from the file it is video recorded by my mobile nokia 5630 xpressmusic
General
Complete name : J:\08122009002.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 8.00 MiB
Duration : 32s 149ms
Overall bit rate : 2 089 Kbps
Encoded date : UTC 2009-12-08 13:46:37
Tagged date : UTC 2009-12-08 13:46:37
Video
Format : MPEG-4 Visual
Format profile : Simple@L4a
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 32s 78ms
Bit rate mode : Variable
Bit rate : 2 000 Kbps
Nominal bit rate : 1 800 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 14.932 fps
Minimum frame rate : 9.236 fps
Maximum frame rate : 33.333 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.436
Stream size : 7.62 MiB (95%)
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 48.0 KHz
Stream size : 377 KiB (5%)
VFR conversion can be tricky, you might get parts slightly in and out of sync
Convert to CFR 15 FPS first (the base frame rate is 15 FPS), then duplicate the frames 2x using ChangeFPS() . Or if you want, just leave it at 15 FPS (unless this is for DVD-video?, then you have to resize as well)
Maximum frame rate : 33.333 fpsCode:DirectShowSource("08122009002.mp4", fps=15, convertfps=true) ChangeFPS(30000,1001) -
You can also interpolate 15 fps -> 30 fps with InterFrame script in AviSynth
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
i want to save HD video with 640x480 AND VERY GOOD QUALITY...HOW??
By khalid81 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jun 2009, 01:40 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17 -
Convert Mobile Video
By phn_uk in forum Video ConversionReplies: 1Last Post: 3rd Jun 2008, 09:27
