Hello. I wonder if anyone might know where I'm going wrong. I've just bought a Disgo TVGO and have followed the ( fairly basic ) instructions ) to set it up. After clicking on Autoscan it identifies my wireless router ( AOL) correctly but when I put in my password it just says 'connecting' for a minute or so then the screen displays a large question mark and the words 'wifi timeout'. I know I've typed in the correct password as it's actually on the router and have never had a problem using it to connect other wifi items. I did look at doing a manual setup but it is asking for SSID ( not sure what that is ), a password ( which I imagine is the wifi password ion the router that I used on autoscan and also the Encryption Protocol and I have no idea what that is either ?! I've written twice to Disgo's helpline ( no tech help available via phone ) but they have not replied and I'm stuck ! Not even sure if this is the right forum but I'd appreciate any help. Preferably in quite simple language as I'm not very savvy in these matters. Many thanks, Tess
Hi, the SSID is the name of your access point. Manual setup is not better than the automatic setup. The only reason why you would need to do that is if your router does not provide DHCP support (automatic assign of IP address)
The Disgo firmware is outdated anyway. You better look at the listenlive firmware which offers much more including news, weather, twitter and the ability to easily customize your favorites. Check out listenlive.nl
PLEASE help if you can re Disgo TVGO (or advise which forum might) Thanks
By Tess111 in forum Portable VideoReplies: 1Last Post: 17th Mar 2012, 09:44 -
need advise on a software
By godesdevine in forum Newbie / General discussionsReplies: 4Last Post: 15th Aug 2010, 21:23 -
New PC build - please advise
By Poppa_Meth in forum ComputerReplies: 44Last Post: 24th May 2010, 13:32 -
New to capture, advise?
By ejjames in forum Capturing and VCRReplies: 7Last Post: 30th Aug 2009, 22:36 -
player advise...
By mohit in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Feb 2009, 11:22
