  1. Hi guys,
    I have QuickTime Apple ProRes 422(HQ) SD PAL footage and I want to convert it to MPEG 2 PAL for DVD. The problem is that every time result is the same - encoded movie is dark. When it plays on TV the encoded movie is darker than the source file. What should I do to correct the movie?
    I receive the footage captured on MAC probably and I work on PC, if this maters...
  2. Member Cornucopia's Avatar
    YES, it matters!
    PCs and MACs have different gamma settings, and those almost ALWAYS affect the encoded video (unless the videographer/editor monitors - and compensates for - via a NTSC/601/709 TV or calibrated Monitor vs. the usual monitor).
    PC gamma is 2.2 and Mac is 1.8 (or vice-versa, I can never remember this one). You'll have to make this gamma adjustment when doing the conversion for everything to work out right.
