Using Win XP Pro 2002 SP3 and DVD Slideshow GUI 0.9.5.0. I get a runtime error (attached) about 70% through the first pass, and another error referring to the MPEG 2 encoder (also attached). The program seems great otherwise, and easy to use, but I have put over 4 hours into creating a slideshow and now can't export it!
I tried deleting the new.ini file and restarting as suggested to emtee in another post, but got the same error again.
Any help appreciated.
I don't have any other applications open at the time (but AVG virus scan is on). The slideshow contains jpg images only, no videos.
Moving you to our dvd authoring section....and maybe you should add dvd slideshow gui to your thread title. You can edit it by click on the edit button and go advanced.
What are you video and images source files? Maybe some corrupt video for example. -
Nope, just jpegs. I have added subtitles that fade--could that be causing an issue? Also do you know of any negative interactions with anti-virus programs? I'm kind of reluctant to turn that off.
Also I should mention that I've already tried reinstalling the program.Last edited by outdoorsyisin; 16th Mar 2012 at 11:36.
DVD Slideshow GUI
By spike47 in forum Newbie / General discussionsReplies: 0Last Post: 15th Apr 2012, 12:23 -
DVD slideshow GUI
By andwan0 in forum Newbie / General discussionsReplies: 2Last Post: 14th Sep 2010, 07:51 -
DVD slideshow GUI Export to mpeg but no audio
By pd-f in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jun 2009, 05:54 -
Burn photos slideshow into a disc–what’s the difference between DVD and CD?
By coody in forum Authoring (DVD)Replies: 5Last Post: 12th Oct 2008, 22:24 -
DVD Slideshow GUI
By Tripodd in forum Authoring (DVD)Replies: 0Last Post: 27th Jul 2007, 14:19
