I have grabbed the audio file from a video using VirtualDub.
I want to add it to a slide show created with "DVD slideshow GUI".
When I try to add the audio file to "DVD slideshow GUI" I get the message : "Can not load the file XXX No compatible ACM codec to decode 0x0161 audio stream to PCM". "Import unsuccessful."
1) Can I change the format of the wav file?
2) Or where can I get a compatible codec?
Details of the audio file I am trying to add from mediainfo:
General
Complete name :XXX
Format : Wave
File size : 27.1 MiB
Duration : 29mn 33s
Overall bit rate : 128 Kbps
Audio
Format : WMA
Format version : Version 2
Codec ID : 161
Codec ID/Info : Windows Media Audio
Duration : 29mn 33s
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 27.1 MiB (100%)
Thanks in advance.
SYSTEM
W7 64bit
Thanks Baldrick. I installed divx wma audio codec but no luck.
It unzipped to a file DivXa32.acm. Is there a specific directory I have to put this file in? (I tried putting DivXa32.acm into "C:\Program Files (x86)\GUI for dvdauthor". Still no joy!)
Any suggestions welcome. -
Try converting the audio file to MP3 using FormatFactory or similar.
This should import directly into DVD slideshow GUI without a hitch. -
When I attempted to run register.exe I received a copy error:
"An error occurred while copying file DivXa32.acm. Cannot copy file to destination directory."
That's why I was going to manually copy the file but I don't know which directory to put it in.
NOTE: DivXa32.acm extracts OK. -
It works fine to install in windows 7...and should work in winxp.
But just try convert the audio to wav instead as transporterfan suggest. Format Factory, Freemake Audio Converter, etc. -
Thanks.
In the end I installed it on another computer running XP 32bit and everything seems to work fine. It reads in the original wav file without any trouble. So I'm wondering if it's a windows 64 bit problem. It would be interesting to know.
ffmpeg GUI that can "copy" into a different container?
By AlanHK in forum Video ConversionReplies: 4Last Post: 22nd Jul 2010, 03:37 -
Adding hebrew subtitle to "Klass" DVD
By Efib in forum Authoring (DVD)Replies: 18Last Post: 23rd Jun 2010, 02:32 -
how to fix "WARN: unknown mpeg2 aspect ratio 1" in DVD Author GUI
By extent in forum Authoring (DVD)Replies: 10Last Post: 23rd Nov 2009, 08:57 -
Question about secret hidden "Back" button in Gui For DVD Author
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 15th Dec 2008, 04:17 -
"Non valid Key" in GUI for DVD Author
By Harry Cover in forum Authoring (DVD)Replies: 1Last Post: 11th Nov 2007, 15:35
