using Virtauldub to frameserve and CCE to encode a divx to svcd, which settings should i use so that the result will fill the whole screen on a widescreen PAL tv?
right now, i am using tmpenc which has a possibility to change the setting into an source aspect ratio of 16:9 and full screen(keep aspect ratio). This setting works fine but CCE is a lot faster and apparently gives a better picture.
Can anyone help?
640x272
23.976 fps
audio 192 kbs
anything else necessary?
i know i could use the settings of tmpenc in CCE when using vfapi, but i think vfapi does'nt work on my machine, i keep getting errors. -
Virtualdub:
Resize to 432*414, expand frame 480*576; If your dvd player can play 23.976 fps, do not framconvert. Else change frame fps 25. Beware that ten you also need to frameconvert the audio, use BBesweet.
Tmpgenc:
load the svcd pal template, and unlock it and do the following changes
video tab: aspect ratio 1:1
high quality
advanced tab:
source aspect ratio 1:1
video arrange method: center custom size
432*414
save the project and convert it in Vfpai
CCE
do what ever you want, but leave the dar flagg 4:3.
I wrote a guide using Tmpgens framserving to CCE (norwegian) you'll find it [URL = http://home.hib.no/studenter/ing99fkt]here[/URL]
[/url] -
Try it with dvd2svcd (option avi to svcd).Attach the cce encoder and at the last moment choose aspect ratio.- 16:9.
It will work fine.visit Cantabria.It,s a peacefull place in the north of Spain (Europe). -
frotsen,
unfortunately, i can't load anything in vfapi, it keeps on giving me errors..:(
i have no clue why -
Since I you did'nt give any error description. You may wanna try a few things:
Tmpgenc: double klick on TMPGEncVFP_Install.
VFPAI: double klick on vifpset file
right klick-> install on the vifp.ini.
PS. You can always use VitualDub or Avisynth
frotsen -
ok..vfapi is working now, and i just converted my divx with vfapi..now i can run it on CCE..
Another question though:
Does CCE use all the setting i entered in the tmpenc project file?
And since CCE 2.50 supports both vdub frameserve AND vfapi files, why would i switch to 2.62? What are the advantages of 2.62 over 2.50? would u guys advise to switch?
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 06:25 -
AVC conversion, Widescreen frame size, editing with Prem Pro CS3
By Soul_Survivor in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 08:44 -
Widescreen to fullscreen conversion
By F8L23 in forum Video ConversionReplies: 15Last Post: 13th Dec 2008, 12:38 -
Encoding 16:9 Widescreen MKV using CCCP pack and CCE results in 4:3 MPEG 2
By octagon69 in forum Video ConversionReplies: 21Last Post: 17th Oct 2008, 20:52 -
CCE guide for PAL to NTSC conversion
By alexs_eu in forum Video ConversionReplies: 9Last Post: 21st Jun 2008, 07:41
