Hello, I'm really new to DV-capturing so forgive me if I ask something really stupid. I did search through all the topics but couldn't find an answer to my question.
I would like to encode my DV-captured AVI with CCE but when I try to load the AVI in CCE I get an error message. Using an Avisynth script doesn't work either: Avisynth can't seem to handle the AVI. And when I try to load the AVI in VirtualDub (to rip the WAV from the AVI) it gives me an error message that it needs a VFW codec. TMPGEnc is able to load and encode it but I prefer CCE. What am I missing to be able to use CCE? Do I need some sort of codec?
nm, I'm using Adobe Premiere 6.0 now with the CCE plugin or the Avisynth plugin.
Look around for a DV codec. My capture machine has a Miro one, since I have StudioDV.
I'm using the MainConcept one on my other machine .. decodes fine, just don't encode unless you want a watermark
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 20:14 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 12:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 14:41 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 19:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
