  1. i am using this code line but i want to make a script (.bat ?)
    ffmpeg -i VIDEO.mov -ss (time that i give ? 00:00:40) -i AUDIO.aac -map 0:0 -map 1:0 -shortest Final.mov
    is this possible ?
    Like you run
    script.bat 00:00:40
    Then you put
    ffmpeg -i VIDEO.mov -ss %1 -i AUDIO.aac -map 0:0 -map 1:0 -shortest Final.mov
    in the script.bat file
    Or do you mean in a loop or?
  3. Originally Posted by Baldrick View Post
    Like you run
    script.bat 00:00:40
    Then you put
    hey baldrick (LOL)
    in another topic i saw this:
    "for %%a in ("*.mov") do ffmpeg -i %%a -map 0:0 -vcodec copy -map 0:1 -acodec copy -map 0:2 %%~na.mov
    pause"
    i would like to add the name for a audio file...this code has only the video name (for loop)... so i want the same code but with the above code....
    I see.
    It would be tricky if the audio and video have different names but if the files are named like video.mov and video.aac could you use
    for %%a in ("*.mov") do ffmpeg -i %%a -ss 00:00:40 -i %%~na.aac -map 0:0 -map 1:0 -shortest final-%%~na.mov
  5. Originally Posted by Baldrick View Post
    I see.
    hmm i tried it and it works..!
    but there is no way i can change the names, they have 2 be the same ?
  6. Originally Posted by lf2 View Post
    I see.
    a tough question i dont know if its possible..
    is it possible to make the -ss dynamic..
    i will try to explane what i am after...
    the meta data video has a creation time : date 00:01:54+0100
    the meta data audio has a creation time: date 00:01:14+0100
    ( 01:54 - 01:14 = 40 (thats the -ss i use)
    is there a way to automaticly take the time off and use that as the -ss ?
    is this possible
