I have some DVDs I ripped using Handbrake's "Normal" profile that I'm trying to play on my BD630, but it just won't do it. I select the file, the screen goes dark for a second then goes right back to the file select screen without playing anything. Does anyone have a combination of encoder/settings that they KNOW will work with the BD630? Thanks in advance.
Results 1 to 10 of 10
And what is this video file playing from....USB stick, external HDD, data CD, data DVD.....what?
Tried both MKV and M4V. The player doesn't even see .M4V files, but I manually renamed it to .MP4, it saw it then but still would not play. I'm playing from a USB stick formatted as FAT32. I've been able to play .AVI files from other sources from the same stick.
Any suggestions? If I wanted to transcode the files to .AVI, what would be the recommended program?
I transcoded one of the files using Vidcoder's normal profile, it defaulted to .mp4. The player still wouldn't play it, but it did give an error saying "cannot play this file" or the like. I made sure the player's firmware was up to date, not sure what else I can try...
Seems I spoke too soon, the audio is out of sync. This is becoming an incredible pain in the ass...
Lg-bd630 stutter problem solved!
By RogerTango in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Feb 2012, 15:18 -
Does the LG BD630 Blu-Ray player play divx?
By hbenthow in forum DVD & Blu-ray PlayersReplies: 15Last Post: 16th Oct 2011, 02:39 -
LG BD630 Blue Ray plays PAL
By wulf109 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Oct 2011, 08:44 -
Cannot stream netflix or youtube to LG BD630
By v-nick in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jun 2011, 09:43 -
Region code hack for BD630?
By leocosta173 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Jun 2011, 00:34
